Date/Time: Thu, 26 Nov 2026 03:19:26 +0000
VWAP Dashed Line not Appearing on Higher Time Frames
View Count: 461
[2026-02-28 15:57:04]
Martin Wunder - Posts: 18
Hello, the dashed line on the VWAP no longer shows on a larger time frame.
If you zoom way in to a 30 second time frame you can see it, but zoom back out and it turns solid.
I Have downloaded the current version, deleted and downloaded data, tried it on a new chart, and recalculated.
It works fine at my office, on any time frame.
Martin
[2026-03-02 14:41:08]
How the line will appear will depend on a number of factors - the most important being how the data is changing from bar to bar. So typically, it is hard to see a difference between the "Dash" and a "Line" over the main portion of a day, but if you look at the very beginning of the VWAP calculation time, then you can see the distinction better.
The bar spacing will also have an impact on this, as a closer spacing will make it look like more of a line.
We can't say why it looks one way on one system and different on another. Our best guess would be that you have different resolutions for the monitor, which is causing different bar spacings to be used.
