Date/Time: Thu, 26 Nov 2026 03:19:27 +0000
Edit account management columns?
View Count: 379
[2026-02-28 13:10:18]
User301059 - Posts: 3
Is there a method to edit the columns in the account management window? There are so many columns none of them are readable - I would like to delete the columns I do not need to see while trading.
[2026-03-02 14:29:33]
There is not a way to remove columns from the Account Management window. But you can move columns around by left-clicking on a column and then dragging it to where you want it to be. You will see a red-line (by default) show where the column is moving to.
We do not know what you mean by "none of them are readable". You can change the width of each column by placing your pointer at edge of a column header and then clicking and dragging that edge. So you can set the widths as you need them. Also, there is a scroll bar at the bottom of the window to allow you to scroll to view the columns that are not currently in view. And if the font is not what you need, then you can change that as well.
