Date/Time: Sun, 08 Nov 2026 21:26:12 +0000
Can't connect to Rithmic/Sierra data feed on latest version 1205
View Count: 1524
[2014-10-23 20:33:29]
User23386 - Posts: 43
I can't connect to the Rithmic data feed using the latest version 1205 on my 2nd pc. I can connect to both the Sierra and Rithmic feeds on my main trading pc but am not able to connect to Rithmic on this pc since the upgrade today. I have to go way back and install an old version to connect to Rithmic. Log file below.
Software version: 1205 | 2014-10-23 16:25:20
Usage end date: 2015-02-07 | 2014-10-23 16:25:20
Enabled for: Advanced Features. | 2014-10-23 16:25:20
Enabled for: Advanced Features 2. | 2014-10-23 16:25:20
Enabled for: Sierra Chart Historical Data Service. | 2014-10-23 16:25:20
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-10-23 16:25:20
Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2014-10-23 16:25:20
Enabled for: DOW INDEXES exchange. | 2014-10-23 16:25:20
Enabled for: S&P INDEXES exchange. | 2014-10-23 16:25:20
Enabled for: NASDAQ INDEXES exchange. | 2014-10-23 16:25:20
Received 1 data feed usernames. | 2014-10-23 16:25:20
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-23 16:25:20
Active service: Rithmic Trading | 2014-10-23 16:25:20
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-10-23 16:25:20
2014-10-23 16:25:20 Local computer clock time | 2014-10-23 16:25:20
2014-10-23 20:25:20 GMT time | 2014-10-23 16:25:20
2014-10-23 16:25:20 Time zone adjusted time | 2014-10-23 16:25:20
Time difference to server time: 2 seconds. | 2014-10-23 16:25:20
Program path: C:\SierraChart\ | 2014-10-23 16:25:20
Data Files path: C:\SierraChart\Data\ | 2014-10-23 16:25:20
OS Version Number: 5.1 | 2014-10-23 16:25:20
Locale Information: C | 2014-10-23 16:25:20
Checking for new symbol settings for rim | 2014-10-23 16:25:20
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-10-23 16:25:20
HTTP connection to www.sierrachart.com:80 (864) | Connected. | 2014-10-23 16:25:20
Requesting symbol settings for rim. Overwrite = off. | 2014-10-23 16:25:20
Symbol settings received. | 2014-10-23 16:25:21
Processed received symbol settings | 2014-10-23 16:25:21
Files to Open on Start up | File does not exist: C:\SierraChart\Data\S&P Emini Workstation.cht | 2014-10-23 16:25:23
Files to Open on Start up | File does not exist: C:\SierraChart\Data\Crude Oil Workstation.cht | 2014-10-23 16:25:23
Rithmic Trading | Port for executable: 2214 | 2014-10-23 16:25:25
Listening socket (1264), port 2214 | Closed. | 2014-10-23 16:25:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:25
HTTP connection to www.sierrachart.com:80 (864) | Closed. No error. | 2014-10-23 16:25:26
HTTP connection to www.sierrachart.com:80 (864) | Shutdown and closed. | 2014-10-23 16:25:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2214 | 2014-10-23 16:25:27
Socket (848) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:28
Socket (848) | Shutdown and closed. | 2014-10-23 16:25:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:28
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:28
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:28
Rithmic Trading | Port for executable: 2216 | 2014-10-23 16:25:30
Listening socket (1276), port 2216 | Closed. | 2014-10-23 16:25:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2216 | 2014-10-23 16:25:32
A request for the latest software update has been made. | 2014-10-23 16:25:32 *
The update is being downloaded in the background. When it is complete, you will be prompted. | 2014-10-23 16:25:32 *
There is no new version available. Thank you. | 2014-10-23 16:25:32 *
Socket (872) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:33
Socket (872) | Shutdown and closed. | 2014-10-23 16:25:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:33
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:33
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:33
Rithmic Trading | Port for executable: 2219 | 2014-10-23 16:25:35
Listening socket (848), port 2219 | Closed. | 2014-10-23 16:25:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2219 | 2014-10-23 16:25:37
Socket (1284) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:38
Socket (1284) | Shutdown and closed. | 2014-10-23 16:25:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:38
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:38
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:38
Rithmic Trading | Port for executable: 2221 | 2014-10-23 16:25:40
Listening socket (872), port 2221 | Closed. | 2014-10-23 16:25:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2221 | 2014-10-23 16:25:42
Socket (1276) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:43
Socket (1276) | Shutdown and closed. | 2014-10-23 16:25:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:43
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:43
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:43
Rithmic Trading | Port for executable: 2223 | 2014-10-23 16:25:45
Listening socket (864), port 2223 | Closed. | 2014-10-23 16:25:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2223 | 2014-10-23 16:25:47
Current selected Data/Trading service: Rithmic Trading | 2014-10-23 16:25:47
Socket (848) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:48
Socket (848) | Shutdown and closed. | 2014-10-23 16:25:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:48
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:48
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:48
Rithmic Trading | Port for executable: 2225 | 2014-10-23 16:25:50
Listening socket (1276), port 2225 | Closed. | 2014-10-23 16:25:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2225 | 2014-10-23 16:25:52
Socket (1260) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:53
Socket (1260) | Shutdown and closed. | 2014-10-23 16:25:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:53
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:53
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:53
Rithmic Trading | Port for executable: 2227 | 2014-10-23 16:25:55
Listening socket (848), port 2227 | Closed. | 2014-10-23 16:25:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:25:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2227 | 2014-10-23 16:25:57
Socket (1260) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:25:58
Socket (1260) | Shutdown and closed. | 2014-10-23 16:25:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:25:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:25:58
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:25:58
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:25:58
Rithmic Trading | Port for executable: 2229 | 2014-10-23 16:26:00
Listening socket (1256), port 2229 | Closed. | 2014-10-23 16:26:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2229 | 2014-10-23 16:26:02
Socket (872) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:03
Socket (872) | Shutdown and closed. | 2014-10-23 16:26:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:03
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:03
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:03
Rithmic Trading | Port for executable: 2231 | 2014-10-23 16:26:05
Listening socket (1260), port 2231 | Closed. | 2014-10-23 16:26:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2231 | 2014-10-23 16:26:07
Socket (848) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:08
Socket (848) | Shutdown and closed. | 2014-10-23 16:26:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:08
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:08
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:08
Rithmic Trading | Port for executable: 2233 | 2014-10-23 16:26:10
Listening socket (872), port 2233 | Closed. | 2014-10-23 16:26:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2233 | 2014-10-23 16:26:12
Socket (1256) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:13
Socket (1256) | Shutdown and closed. | 2014-10-23 16:26:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:13
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:13
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:13
Rithmic Trading | Port for executable: 2238 | 2014-10-23 16:26:15
Listening socket (848), port 2238 | Closed. | 2014-10-23 16:26:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2238 | 2014-10-23 16:26:17
Socket (1452) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:17
Socket (1452) | Shutdown and closed. | 2014-10-23 16:26:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:17
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:18
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:18
Rithmic Trading | Port for executable: 2246 | 2014-10-23 16:26:20
Listening socket (1480), port 2246 | Closed. | 2014-10-23 16:26:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2246 | 2014-10-23 16:26:22
Socket (1472) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:23
Socket (1472) | Shutdown and closed. | 2014-10-23 16:26:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:23
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:23
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:23
Rithmic Trading | Port for executable: 2251 | 2014-10-23 16:26:25
Listening socket (1452), port 2251 | Closed. | 2014-10-23 16:26:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2251 | 2014-10-23 16:26:27
Socket (848) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:27
Socket (848) | Shutdown and closed. | 2014-10-23 16:26:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:27
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:27
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:27
Rithmic Trading | Port for executable: 2253 | 2014-10-23 16:26:29
Listening socket (1472), port 2253 | Closed. | 2014-10-23 16:26:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2253 | 2014-10-23 16:26:31
Socket (1480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:32
Socket (1480) | Shutdown and closed. | 2014-10-23 16:26:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:32
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:32
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:32
Rithmic Trading | Port for executable: 2255 | 2014-10-23 16:26:34
Listening socket (848), port 2255 | Closed. | 2014-10-23 16:26:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2255 | 2014-10-23 16:26:36
Socket (1444) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:38
Socket (1444) | Shutdown and closed. | 2014-10-23 16:26:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:38
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:38
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:38
Rithmic Trading | Port for executable: 2263 | 2014-10-23 16:26:40
Listening socket (1480), port 2263 | Closed. | 2014-10-23 16:26:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2263 | 2014-10-23 16:26:42
Socket (1452) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:42
Socket (1452) | Shutdown and closed. | 2014-10-23 16:26:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:42
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:42
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:42
Rithmic Trading | Port for executable: 2265 | 2014-10-23 16:26:44
Listening socket (1444), port 2265 | Closed. | 2014-10-23 16:26:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2265 | 2014-10-23 16:26:46
Socket (1472) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:47
Socket (1472) | Shutdown and closed. | 2014-10-23 16:26:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:47
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:47
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:47
Rithmic Trading | Port for executable: 2273 | 2014-10-23 16:26:49
Listening socket (1452), port 2273 | Closed. | 2014-10-23 16:26:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2273 | 2014-10-23 16:26:51
Socket (1480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:52
Socket (1480) | Shutdown and closed. | 2014-10-23 16:26:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:52
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:52
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:52
Rithmic Trading | Port for executable: 2275 | 2014-10-23 16:26:54
Listening socket (1472), port 2275 | Closed. | 2014-10-23 16:26:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2275 | 2014-10-23 16:26:56
Socket (1444) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:26:57
Socket (1444) | Shutdown and closed. | 2014-10-23 16:26:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:26:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:26:57
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:26:57
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:26:57
Rithmic Trading | Port for executable: 2277 | 2014-10-23 16:26:59
Listening socket (1480), port 2277 | Closed. | 2014-10-23 16:26:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:26:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2277 | 2014-10-23 16:27:01
Socket (1452) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:02
Socket (1452) | Shutdown and closed. | 2014-10-23 16:27:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:02
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:02
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:02
Rithmic Trading | Port for executable: 2279 | 2014-10-23 16:27:04
Listening socket (1444), port 2279 | Closed. | 2014-10-23 16:27:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2279 | 2014-10-23 16:27:06
Socket (1472) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:07
Socket (1472) | Shutdown and closed. | 2014-10-23 16:27:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:07
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:07
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:07
Rithmic Trading | Port for executable: 2281 | 2014-10-23 16:27:09
Listening socket (1452), port 2281 | Closed. | 2014-10-23 16:27:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2281 | 2014-10-23 16:27:11
Socket (1480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:12
Socket (1480) | Shutdown and closed. | 2014-10-23 16:27:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:12
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:12
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:12
Rithmic Trading | Port for executable: 2283 | 2014-10-23 16:27:14
Listening socket (1472), port 2283 | Closed. | 2014-10-23 16:27:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2283 | 2014-10-23 16:27:16
Socket (1444) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:17
Socket (1444) | Shutdown and closed. | 2014-10-23 16:27:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:17
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:17
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:17
Rithmic Trading | Port for executable: 2285 | 2014-10-23 16:27:19
Listening socket (1480), port 2285 | Closed. | 2014-10-23 16:27:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2285 | 2014-10-23 16:27:21
Socket (1480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:22
Socket (1480) | Shutdown and closed. | 2014-10-23 16:27:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:22
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:22
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:22
Rithmic Trading | Port for executable: 2288 | 2014-10-23 16:27:24
Listening socket (848), port 2288 | Closed. | 2014-10-23 16:27:24
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2288 | 2014-10-23 16:27:26
Socket (1472) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:27
Socket (1472) | Shutdown and closed. | 2014-10-23 16:27:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:27
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:27
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:27
Rithmic Trading | Port for executable: 2290 | 2014-10-23 16:27:29
Listening socket (1480), port 2290 | Closed. | 2014-10-23 16:27:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2290 | 2014-10-23 16:27:31
Socket (1456) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:33
Socket (1456) | Shutdown and closed. | 2014-10-23 16:27:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:33
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:33
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:33
Rithmic Trading | Port for executable: 2292 | 2014-10-23 16:27:35
Listening socket (1472), port 2292 | Closed. | 2014-10-23 16:27:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2292 | 2014-10-23 16:27:37
Socket (848) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:37
Socket (848) | Shutdown and closed. | 2014-10-23 16:27:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:37
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:37
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:37
Rithmic Trading | Port for executable: 2294 | 2014-10-23 16:27:39
Listening socket (1456), port 2294 | Closed. | 2014-10-23 16:27:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2294 | 2014-10-23 16:27:41
Socket (1480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:42
Socket (1480) | Shutdown and closed. | 2014-10-23 16:27:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:42
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:42
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:42
Rithmic Trading | Port for executable: 2296 | 2014-10-23 16:27:44
Listening socket (848), port 2296 | Closed. | 2014-10-23 16:27:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2296 | 2014-10-23 16:27:46
Socket (1472) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:48
Socket (1472) | Shutdown and closed. | 2014-10-23 16:27:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:48
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:48
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:48
Rithmic Trading | Port for executable: 2298 | 2014-10-23 16:27:50
Listening socket (1480), port 2298 | Closed. | 2014-10-23 16:27:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:27:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2298 | 2014-10-23 16:27:52
Socket (1452) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:27:52
Socket (1452) | Shutdown and closed. | 2014-10-23 16:27:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:27:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:27:52
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:27:52
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:27:52
Rithmic Trading | Port for executable: 2301 | 2014-10-23 16:30:52
Listening socket (1472), port 2301 | Closed. | 2014-10-23 16:30:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-23 16:30:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 2301 | 2014-10-23 16:30:54
Socket (1448) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-23 16:30:56
Socket (1448) | Shutdown and closed. | 2014-10-23 16:30:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-23 16:30:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-23 16:30:56
Rithmic Trading | Disconnected from the server. | 2014-10-23 16:30:56
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-23 16:30:56
[2014-10-24 01:49:24]
We apologize for the delay here. This is the result of a no API component from Rithmic which does not work on Windows XP.
We are going to be putting on a technical notice about this.
You need to stay on an earlier version. We will let you know what the latest version you can use with Windows XP is, when using Rithmic.
[2014-11-05 08:43:58]
User28973 - Posts: 8
that I am the last version of xp? and by when will we be able to use XP system? thank you
[2014-11-05 11:15:04]
We are not understanding the question. Is this in regards to the Rithmic connection? Rithmic does not support Windows XP any longer.
Date Time Of Last Edit: 2014-11-05 11:15:31
