Date/Time: Thu, 26 Nov 2026 03:19:27 +0000
2 items and 2 stand alone doms
View Count: 327
| [2026-02-26 06:03:41] |
| User360283 - Posts: 538 |
How do I have the stand alone DOM show the same instrument as the chart? thanks |
| [2026-02-26 15:01:22] |
The simple answer to your question is to use the option for "File >> Open Trading DOM for Chart", which will open a Trading DOM for the same symbol as the active chart. Also refer to the following for how to change the symbol for a chart: Changing the Symbol of a Chart If you are changing symbols in a chart and want the Trading DOM to also change symbols, then you would need to use the "Linking" option for "Symbol" between those two items. Refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
