Date/Time: Thu, 26 Nov 2026 03:31:22 +0000
RECTANGLE COLOR MODIFICATION
View Count: 342
| [2026-02-26 03:42:12] |
| usgvince - Posts: 30 |
WOULD YOU CONSIDER MODIFYING THE RETANGLE DRAWING PROPERTIES SETTINGS TO PRODUCE A 2 COLOR FILL ON A RETANGE WHEN A MID LINE PROPERTY IS SELECTED? TOP HALF WILL BE FILLED WITH ONE COLOR AND THE BOTTOM HALF WITH A SECOND COLOR. THANKS |
| [2026-03-05 02:08:48] |
It's easier to get distracted with a chart when there's lots of study lines from different studies. Two studies come to mine. Swing High/Low and Volume by Price. It would be to nice remove any old lines that intersect. Keep all lines that did not intersect, but delete or color the line the same color as the background so it's not visible. Do the same for the POC and other similar studies that generate lines. You could put a yes/no in the configuration for hiding spent lines or keeping all lines. Thanks |
