Date/Time: Thu, 26 Nov 2026 03:19:31 +0000
Perform Symbol Rollover no longer allows symbol change
View Count: 466
| [2026-02-25 18:44:24] |
| User719512 - Posts: 548 |
Sierra Chart Engineering, With the new dialog for Perform Futures Symbol Rollover, you can no longer change the symbol on the chart. You used to be able to Type the desired symbol into the combobox if you did not want to select from the auto-populated rollover symbol. This allowed one to effectively change the symbol on all charts from ESH26 to NQH26 for example, rather than only ES (H26 to M26). Would be nice to see some UP VOTES or LIKES on this post to indicate the popularity of this "feature" of the old perform futures symbol rollover. Can this be done with the new dialog framework and make that dropdown a combobox? |
| [2026-02-25 21:01:56] |
| Sierra_Chart Engineering - Posts: 25489 |
This is resolved in the latest prerelease. Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
