Date/Time: Thu, 26 Nov 2026 03:19:29 +0000
sierra shut down?
View Count: 350
| [2026-02-25 18:42:00] |
| User166249 - Posts: 28 |
Hi DATA FEED is shut down on my sierra since 13H00. Is it only mine or general server shut donw? thank |
| [2026-02-25 18:43:15] |
correction : since 12h45
| [2026-02-25 18:54:03] |
There was an issue with some metals and Natural Gas at that time due to a halt from the CME Group. Refer to the following: https://www.cmegroup.com/tools-information/cme-global-command-center-system-alerts.html If it is something else, then we would need to know the symbol you had an issue with. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
