Date/Time: Thu, 26 Nov 2026 03:19:31 +0000
Tiling charts across multiple chartbooks
View Count: 426
| [2026-02-25 14:45:19] |
| User14953 - Posts: 268 |
Please consider adding support for tiling charts across multiple chartbooks. Currently, the Tile Vertically command appears to arrange only the windows that belong to the currently active Sierra Chart instance and its single visible chartbook. Within one instance, only one chartbook can be visible at a time, so tiling applies only to the charts in that chartbook. I would like the ability to have charts from two different chartbooks visible and tiled side‑by‑side within the same instance, without needing to run a second Sierra Chart instance to position the two application windows. |
| [2026-02-25 16:15:55] |
| Sierra_Chart Engineering - Posts: 25489 |
The Tile command is only ever going to affect the active Chartbook. This is not going to be anything that would ever change. What is coming is the ability to have multiple Main windows in Sierra Chart with their own MDI child windows.
