Date/Time: Wed, 25 Nov 2026 23:10:15 +0000
[User Discussion] - SierraChart\Data\SierraChartStudies.dll is missing the SCDLLName line.
View Count: 444
[2026-02-23 21:32:07]
James D - Posts: 14
I keep getting the errors below when trying to open a Chartbook; everything was fine two days ago.
Alert Formula Error - Chart: EURUSD[M] Weekly #18 | Study: The custom study "F:\SierraChart\Data\SierraChartStudies.dll" is missing the SCDLLName line. Windows error code 0: The operation completed successfully. | Error: The formula has no value. | Formula: = | No alert sound/email.
Alert Formula Error - Chart: EURUSD[M] 125 Min #6 | Study: The custom study "F:\SierraChart\Data\SierraChartStudies.dll" is missing the SCDLLName line. Windows error code 0: The operation completed successfully. | Error: The formula has no value. | Formula: = | No alert sound/email.
Alert Formula Error - Chart: EURUSD[M] 25 Min #2 | Study: The custom study "F:\SierraChart\Data\SierraChartStudies.dll" is missing the SCDLLName line. Windows error code 0: The operation completed successfully. | Error: The formula has no value. | Formula: = | No alert sound/email.
[2026-02-23 22:53:28]
First, check to ensure that you have enough space on the F: drive where you have your Sierra Chart installed. We wonder if the SierraChartStudies.dll file got corrupted due to not enough space on the drive.
If you have enough space, then you will need to update to the latest release. You are running a very old version and you need to update. Follow these instructions to update:
If you continue to have an issue with that file, even after updating, then make sure that your Virus Scanning software is not removing it. You should put in an exception for the entire Sierra Chart folder in your virus scanning software to ensure that it does not remove something it should not be.
[2026-02-23 23:44:10]
Sierra_Chart Engineering - Posts: 25485
This is unusual.
See if this file exists on your system and let us know the file size of it:
