Date/Time: Wed, 25 Nov 2026 23:10:06 +0000
SGN - 1 particular stock not updating
View Count: 549
| [2026-02-23 09:47:49] |
| User493740 - Posts: 6 |
Hi there, I have an issue with one stock not updating. The ticker is SGN. In the same chart and quote book, all other tickers are fine apart from this one. I added the ticker to the quote board along with another ticker and attached it to this ticket. The time is 4.32am and you can see VHUB is updating but SGN is not. The bid, ask and volume for SGN is updating but all the other info is not, almost like this ticker got stuck at 19.00 the day before. I've tried deleting the chart data and redownloading but nothing changes for this one. Do you have any suggestions? Thanks |
| [2026-02-23 13:06:19] |
| User383986 - Posts: 18 |
I can see it is not loading for me too. You can see bid/ask moving, chart itself is not updating.
Date Time Of Last Edit: 2026-02-23 13:16:09
| [2026-02-23 13:23:58] |
Another one with GETY too just now. I've attached the screenshot showing bid/ask is being updated on quote board but everything else seems to be stuck at 19.00. Same issue.
| [2026-02-23 14:01:38] |
Now another one with the symbol AIM. Screenshot attached.
| [2026-02-23 14:05:27] |
Now another one with symbol ALUR. Any help would be appreciated. Hopefully it's something I'm doing and not the Denali data feed, because then it would be useless for equities. |
| [2026-02-23 14:14:40] |
| funbun - Posts: 94 |
ALUR indeed is not updating, the rest do
| [2026-02-23 14:36:15] |
| joshtrader - Posts: 569 |
Guys, check the other thread. SC Engr is looking into it.
| [2026-02-23 14:54:12] |
Which thread is that? I installed a new version of Sierra Charts from scratch and it also had the same issues, so it's not on my end. |
| [2026-02-23 17:18:32] |
There was an issue with the U.S. Equities Consolidated Tape which has been resolved.
| [2026-02-23 18:13:42] |
Thanks John, when can we download that data that was missed? There's a gap for those tickers for this morning to around 11am. I tried deleting and redownloading but there's nothing there for that gap. I've attached a screenshot of my graph. Thanks. |
| [2026-02-23 22:35:29] |
The missing data will be patched tonight (Central US time). So it should be there in the U.S. morning time.
| [2026-02-24 06:20:45] |
| Sierra_Chart Engineering - Posts: 25485 |
The missing data has been patched. To download the missing data, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
