Date/Time: Wed, 25 Nov 2026 23:10:09 +0000
Cannot find saved drafts of support ticket posts
View Count: 362
| [2026-02-22 22:38:25] |
| diatom - Posts: 9 |
Hi For a support ticket I had on the go, I accidentally clicked save as draft. Now I cannot see it. Where do I go in my account to see these? Thanks Mark |
| [2026-02-22 22:43:27] |
| Sierra_Chart Engineering - Posts: 25485 |
Do you know what thread on the message board, that it was saved into? It will be at the bottom of that thread. There will be a button to load the draft. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-23 07:59:04] |
| diatom - Posts: 9 |
I posted to the support board, but that surely should not matter as I was expecting to see the draft under View My Posts / Threads. I dont understand why my drafts do not show under View My Posts / Threads.
| [2026-02-23 16:08:05] |
We see your draft is for a new thread, so you should be able to view it if you start a blank thread. Select the link below and then note a line for the drafts above the entry for the thread. If you have more than 1 draft, it will be a single line that states "# Drafts". So you will need to click on this to view your drafts. https://www.sierrachart.com/SupportBoard.php?do=NewThread&ForumID=0 Sierra Chart Support Date Time Of Last Edit: 2026-02-23 17:26:29
