Date/Time: Wed, 25 Nov 2026 23:10:07 +0000
All charts in all chartbooks are black screens
View Count: 381
[2026-02-22 20:04:19]
User303857 - Posts: 201
Hello Support
All charts in all chartbooks are black screens in all instances.
Restarted in safe mode ... same problem
Selected load no charts in safe mode same problem when opening any chart books or a new chat
Sim mode.... same problem
Update translate charts to current service ... same problem
Shut down computer & restart .... same problem
It is updated to the current version
Date Time Of Last Edit: 2026-02-22 20:06:49
[2026-02-22 20:40:59]
Sierra_Chart Engineering - Posts: 25485
Completely black?
Open one of the Chartbooks and then:
Provide a copy of the Message Log by following these instructions:
This will provide us the additional information we need.
[2026-02-22 20:48:19]
Message log
I tried a new intraday chart and same problem black screen , tried opening up an older chart book same problem.
(Log removed. No obvious issue.)
Date Time Of Last Edit: 2026-02-22 22:31:19
[2026-02-22 22:11:16]
Rolled back the version and still nothing.
Updated again to the current version .... still no visible anything
Opened 2 other instances and nothing on them either.
File attached
Date Time Of Last Edit: 2026-02-22 22:16:28
imageNOTHING.png / V - Attached On 2026-02-22 22:11:10 UTC - Size: 36.33 KB - 150 views
[2026-02-22 22:30:56]
Are you available for us to call and do a remote assistance session so we can look into this?
[2026-02-22 23:56:09]
Yes, give an idea of what time?
[2026-02-23 00:02:03]
We are able to call right now. Confirm that is all right.
Date Time Of Last Edit: 2026-02-23 00:02:18
[2026-02-23 00:03:53]
yes
[2026-02-23 00:20:26]
User has been called. The issue was that OpenGL was enabled and we do not know why on the user's system, when using OpenGL, there was no graphics rendering at all.
[2026-02-23 00:28:17]
Thanks for the assistance, I will keep open GL off, probably forever.
Here is the vertical price line from the built in studies... not sure if it is accurate.
Private File
