Date/Time: Wed, 25 Nov 2026 23:10:10 +0000
Market Depth half screen
View Count: 308
| [2026-02-22 19:18:50] |
| User203631 - Posts: 27 |
whenever I'm scrolling in and out using my mouse the market depth will either cover the entire chart or it'll shift left and I'm left with a blank chart. how can i keep the market depth on the entire chart while also being able to zoom in and out. |
| [2026-02-22 19:31:33] |
| Sierra_Chart Engineering - Posts: 25485 |
Why are there no chart bars in this image: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=134237 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-22 19:31:43
| [2026-02-22 19:36:26] |
The graph draw type is set to "stair step on close", as i zoom in the market depth shifts left and im left with a blank screen to the right.
| Attachment Deleted. |
| [2026-02-22 20:42:47] |
I figured it out, "percentage of fill space to display market depth quantity rectangles in" was at 20 instead of 100. Thank you for your help. |
