Date/Time: Wed, 25 Nov 2026 23:10:11 +0000
Drawings not copying
View Count: 375
| [2026-02-21 06:49:57] |
| DrinkMoreWater - Posts: 15 |
Hello. I have chart #2 and I have chart #3, #8, and #7 copying their chart drawings to chart #2. Chart #3 and #7 copy and show up successfully on chart #2. Chart #8 however does not copy the drawings like the others do. Chart #8 and #7 are both TPO charts Chart #2 has "3,7,8" in the copy settings. (I have tried different variation, with and without spaced after commas, etc) All drawings on chart #8 have "Allow copy to other charts" enabled Reload and recalculate did not fix the issue Duplicating the chart and adding that chart # into the copy field of chart #2 also did not work. Thank you |
| [2026-02-23 15:28:32] |
Please get us that Chartbook by following these instructions and we'll take a look and see if we can figure out what is occurring: Support Board Posting Information: Attaching a File (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-23 15:31:56] |
I actually figure it out. I was plotting my drawings starting from the left of the screen and dragging it to the right. So I think I was drawing on the TPO layer. Started drawing from the blank space to the right and then to the TPO and they started showing up! |
| [2026-02-23 17:20:27] |
Drawings done on TPO charts can be finicky, as the TPO does not have the same concept of time like a standard chart, so the way the dates/times match up can be different from what you expect.
