Date/Time: Thu, 26 Nov 2026 04:01:32 +0000
[Programming Help] - Tagging A User Drawing
View Count: 447
| [2026-02-20 18:29:30] |
| User688525 - Posts: 403 |
Hello Sierra Chart, Is there a tag or unique identifier (separate to the line number) that can be used to silently differentiate a drawing from a source chart on a destination chart? I want to avoid using text on the destination chart so that the chart remains clean. Instead, if an internal "tag" (or similar concept) can be used, the drawing can then be identified with a custom study. Thank you |
| [2026-02-21 05:16:33] |
| Sierra_Chart Engineering - Posts: 25489 |
These Chart Drawings are internally already identified by the source chart number and the source Chartbook. We will make sure those variables are set in the corresponding ACSIL drawing structure.
| [2026-02-22 02:30:35] |
Thank you. Once implemented, which technical documentation page(s) will be updated to reflect the changes and required ACSIL code? |
| [2026-04-04 22:30:33] |
Hello Sierra, Separate to the above, is there a way to identify if "Allow Copy to Other Charts" is enabled on a chart drawing? Thank you |
| [2026-04-05 13:37:57] |
Yes, through this structure member: s_UseTool::AllowCopyToOtherCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-05 13:37:58] |
| [2026-04-05 21:29:22] |
Thank you. Works perfectly!
