Date/Time: Wed, 25 Nov 2026 23:10:10 +0000
keybord short cut
View Count: 324
| [2026-02-20 16:01:39] |
| User166249 - Posts: 28 |
Hi I set keybord shortcut for buy ASK et SELL BID button but nothing work. only message log oppened. ive tryed everythng on the support bord i send you screenshot attached thnk you |
| [2026-02-20 16:18:11] |
The Message Log is coming up and is telling you that in order to use the Keyboard Shortcuts, you need to enable the option for "Trade >> Trading Keyboard Shortcuts Enabled". Refer to the following: Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
