Date/Time: Wed, 25 Nov 2026 23:10:06 +0000
sc.FileRecordIndexOfLastDataRecordInChart
View Count: 265
| [2026-02-20 14:15:32] |
| User907968 - Posts: 887 |
When restricting data in chart using the 'Use Date Range' setting, sc.FileRecordIndexOfLastDataRecordInChart returns an unexpected value at the last bar in the chart. It would appear that the value returned reflects the last record in the chart if the data was loaded up to and including the current day, rather than the last loaded bar - is that expected behavior? |
| [2026-02-20 20:08:20] |
| Sierra_Chart Engineering - Posts: 25485 |
We need to look into this and resolve that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-20 20:09:12
