Date/Time: Wed, 25 Nov 2026 23:10:13 +0000
Software connection
View Count: 347
| [2026-02-19 20:23:01] |
| Serajeddean - Posts: 8 |
Hello, hope you are well. If I buy a Huawei mate book fold, will Sierra Chart work on it or it only works on Windows? Could there be a way to have it working on a Huawei laptop? Thank you. |
| [2026-02-20 02:26:39] |
| Sierra_Chart Engineering - Posts: 25485 |
What is the operating system? And what is the CPU that it uses?
| [2026-02-20 12:21:35] |
Operating System: HarmonyOS 5 CPU System: Huawei Kirin X90 |
| [2026-02-20 20:19:50] |
We think it would be unlikely, that Sierra Chart would run on that computer. The question is whether it can run a Windows program. If it does not specify that it can, then Sierra Chart will not run on it.
