Date/Time: Wed, 25 Nov 2026 23:10:07 +0000
How to change the increment of the chart value crosshair?
View Count: 319
[2026-02-19 18:00:58]
User215923 - Posts: 2
For example I am on BTC chart and if I have the crosshair at 66100 and move it up by one increment the next value it shows will be 66110, being an increment of 10. How would I change it to increments of 1 or 0.1 etc.
[2026-02-19 18:48:22]
The increment that the crosshairs are going to move is set by the Tick Size of the chart. Refer to the following:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2026-02-19 18:52:52]
Thank you John
