Date/Time: Wed, 25 Nov 2026 23:10:13 +0000
[User Discussion] - Custom Studies
View Count: 399
| [2026-02-19 16:16:43] |
| cmack1011 - Posts: 201 |
Hi Can you provide any guidance on using an AI engine with/inside SC? Is there any AI engine you recommend? Is there any specific "set-up" or alignment with SC that works best? One issue that I have found is that the AI engine cannot ever "see" the platform and thus is having to always "guess" what is and is not working when developing a custom study. Is there any way to allow the AI engine to better see what is happening on the platform? Thx |
| [2026-02-21 17:04:03] |
Can someone please respond to this question? I have reviewed the support database and I do not find information specifically related to these questions. Thank you.
Date Time Of Last Edit: 2026-02-21 17:05:01
| [2026-02-21 18:06:32] |
| User708541 - Posts: 215 |
Your question is hard to answer because it's not clear what you are trying to do. Are you trying to create a custom study and want the code for the custom study written by an AI engine? If so, I don't think that is very difficult (depending on the requirements of the study). Sierra's documentation is very complete, describing every ACSIL function. So, an AI engine should be able to read all the documentation and provide code that is very close to what you need. You'll most likely have to trouble shoot the code, but AI can probably do that as well. What AI engines have you tried? |
