Date/Time: Wed, 25 Nov 2026 23:10:11 +0000
Updated from 2747 to 2882 and seeing font changes.
View Count: 368
[2026-02-19 13:23:51]
User92573 - Posts: 622
Dear Support,
Just getting back into SC and have undated the version on one of my installs from 2747 to 2882. This was an update rather than installation hence the .cfg file is un-changed so a little unsure as to why I'm seeing some font changes.
Can you tell me which setting controls the font seen in the attached. I'd like to recover the prior setting which is more appropriate as can be seen.
Many thanks.
imageSierra Version Change - Font Change.png / V - Attached On 2026-02-19 13:23:27 UTC - Size: 47.59 KB - 175 views
[2026-02-19 14:59:35]
The font setting is "Tool Drawing Configuration Window". Refer to the following:
Graphics Settings: Tool Drawing Configuration Window
[2026-02-19 15:38:24]
Hi John
Nice to be back on my preferred platform of more than a decade and even better to know there is proper support for the Platform I'm using.
TBH I had to change until a flexible copier solution became available.
Thank you for the directions. All sorted.
Many thanks.
