Date/Time: Sat, 07 Nov 2026 14:02:12 +0000
Trade DOM vs Chart DOM Graphics Settings : Current Traded Ask Volume Bid Volume Difference
View Count: 814
| [2026-02-18 21:54:01] |
| Sébastien - Posts: 156 |
Hi, I use V2883. In this version, the Graphic Settings for the Current Traded Ask Volume Bid Volume Difference Columns are not the same for the Chart DOM and Trade DOM. See screenshots down bellow. Could you please make the Trade DOM Graphic Settings the same as Chart DOM Graphic Settings ? Chart DOM Settings are more complete. Regards, Sebastien |
| [2026-02-18 23:19:55] |
| Sierra_Chart Engineering - Posts: 25397 |
We apologize for this. This will be corrected in the next release.
| [2026-02-19 19:59:20] |
Thank you very much for your fast and amazing work !
| [2026-02-25 19:12:27] |
Hi, I just spotted a bug about one of these graphic settings. On V2886, on a Trade DOM, when "Use Global Graphics Settings Instead of These Settings" in unchecked, the color parameter of Trade DOM Current Traded Ask Volume Bid Volume Difference Negative Volume Bar is not registered after saving, exiting and reloading a chartbook. It returns to the default color every time (grey). |
| [2026-02-25 21:04:45] |
We will check on this and resolve.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-25 21:04:52
| [2026-07-03 16:46:53] |
| Brookwood - Posts: 45 |
Just bumping this thread-- Please put Chart Dom Diagonal text on this list as well-- The Customize Trade Columns and Graphics Settings are named differently. I had a devil of a time finding the color settings for that column by searching for "diagonal". =) Date Time Of Last Edit: 2026-07-03 16:47:32
| [2026-07-13 19:45:57] |
Update to the latest prerelease of Sierra Chart. Instructions: Software Download: Fast Update This is version 2928. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
