Date/Time: Wed, 25 Nov 2026 23:10:10 +0000
Unable to load data
View Count: 339
| [2026-02-18 17:20:20] |
| User939462 - Posts: 1 |
Hey, I am on ESH25-CME and I have the CME data with SC using the Denelli feed. I am trying to have my chart load 180 days of intraday data for RTH session daily candles, but I am unable to do this. When I turn off the continuous futures contract, it loads, but obviously I can’t draw a profile across those days and need the continuous contract back adjusted. When I then load continuous futures contracts, it won’t load more than 30 days, even though my chart data is set to 180 days. I am not sure what to do at this point, this is the only thing i need complete before i can get started trading everything else is set and ready to go thank you for your time |
| [2026-02-18 17:20:29] |
There should not be an issue with this, as long as you have the "Days to Load" set to 180 and you have a Continuous Contract option setup. What exactly occurs in this case? When you have this setup, then scroll all the way to the left in your chart and then get us an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-18 17:32:18] |
| User135243 - Posts: 337 |
we are in 2026 (and not 2025)
