Date/Time: Wed, 25 Nov 2026 23:10:11 +0000
Regarding data feed
View Count: 501
| [2026-02-18 04:13:43] |
| ArmaanSingh - Posts: 23 |
Hi, as I had your CME group exchange data feed active, but today I read this line on your website that says, "In order to avoid paying exchange fees twice when using the Denali Exchange Data Feed with a supported Trading service, you will want to cancel any exchange fees that you pay to the Trading service since you will be using the Denali Exchange Data Feed for data" SO as I using Teton CME routing, and Denali data feed is active, Does that mean that I can deactivate the CME Group data feed, but still recieveing the real time data for the pairs I trade- ES, GC futures, NQ. And lastly, I am about to activate Nasdaq data feed, because I need to get stocks data, SO should I stop it Thanks, I would look forward to you. |
| [2026-02-18 14:55:18] |
What that line is referring to is if you are have a Trading Service where you are also paying for data. Such as if you were connected to Rithmic, and paying Rithmic for the CME Group data, while also having our Denali Exchnage Data Feed for the CME Group data. In this case, you are paying twice for data, once to Rithmic and again to us. This situation does not apply to you, as you are using the Teton Order Routing Service, so you have to get your data from our Denali Exchange Data Feed, as there is no other option for how to get the data. The same is true for the equities data - if you want the real-time data, then you will need to get it from our Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
