Date/Time: Wed, 25 Nov 2026 23:10:13 +0000
Market Depth Historical Graph - How to Reducing Memory Usage?
View Count: 1361
[2026-02-17 18:25:37]
User823887 - Posts: 5
Hi SC support,
I've reviewed the Market Depth Historical Graph documentation and the Improving Performance section, but the available options (Days to Load, Maximum Levels to Display, Chart Update Interval) do not fully address my situation.
I'm running two Market Depth Historical Graph charts (ES and NQ) with Days to Load set to 1 and the Graph Historical Market Depth Data Time Period set to 100ms, as I need to capture short-term order book changes. I understand that increasing this to 500ms or 1s would reduce memory, but that would defeat the purpose for my use case.
Currently Sierra Chart is using about 16 GB of memory. There is no lag or performance issue — the software runs great. I'm just looking for ways to reduce memory usage while keeping the 100ms time resolution.
Are there any other recommended settings or approaches I may be overlooking? For example, would something like limiting the loaded data to only the most recent 1-2 hours instead of the full trading day be possible?
Thank you.
[2026-02-17 18:42:42]
Cutting down the data loaded in the chart would help, but there is not a good way to only load a few hours for a chart. The only way to do this would be to constantly change the Session Times.
The only other thing we can suggest is limiting the number of depth levels that are displayed. Refer to the following:
Market Depth Historical Graph: Maximum Levels to Display (0 for All)
[2026-02-18 16:32:49]
Thank you for the suggestions. Adjusting the Session Times is helpful for my case since I only trade during the NY session and don't need the overnight data loaded.
If possible, it would be great to have a more granular data limiting option for the Market Depth Historical Graph in the future — for example, limiting by hours or minutes — so that memory usage can be reduced without having to manually adjust Session Times. Just a suggestion for consideration.
Thank you again.
