Date/Time: Wed, 25 Nov 2026 23:10:13 +0000
Drawn VP issue in region 2
View Count: 370
| [2026-02-17 16:44:52] |
| User940772 - Posts: 85 |
I decided to put my main chart in region 2 and one of my studies in region 1. My problem is I cannot right click on drawn Volume Profiles to edit or delete any longer. On all charts that are configured normally this function remains intact. I looked through the help files but can't figure this one out. Any suggestions would be appreciated ... Thanks.
| [2026-02-17 18:22:32] |
We are able to reproduce what you are seeing. We will have to look into this. In the meantime, you can delete a Drawn Volume Profile through the "Analysis >> Studies" window, as these are actually stored as studies, so you remove the study associated with the drawn profile you want to remove. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-17 19:01:50] |
Okay John, I'll wait for the fix, thanks.
| [2026-02-19 00:02:53] |
| Sierra_Chart Engineering - Posts: 25485 |
This will be resolved in the next release.
| [2026-02-19 02:18:13] |
Thanks for the update and quick turnaround on the fix. Very much appreciated.
