Date/Time: Wed, 25 Nov 2026 23:10:06 +0000
[User Discussion] - Maintain Risk-Reward Ratio Between Target and Stop Attached Orders
View Count: 412
| [2026-02-16 21:11:19] |
| NorthernTrader_21 - Posts: 15 |
Hello! I want my take profit to be automatically adjusted when I move my stop loss so that the ratio between them is maintained in my OCO order. So for instance if the offset on my stop loss is 10 ticks and the offset for my take profit is 20 ticks then that means I have a 1:2 risk to reward, when I deploy my OCO-order and I drag my stop loss down say 5 ticks then my take profit should move up 10 ticks to maintain this 1:2 ratio and vice-versa. I read through these pages but didn't find that feature, apologies if I missed it. Chart Trading and the Chart DOM Attached Orders |
| [2026-02-16 21:40:08] |
| ForgivingComputers.com - Posts: 1256 |
I can create a custom study that does this. I sent you a DM request. Brad |
| [2026-02-16 22:40:41] |
There is no built-in method to do what you are wanting. A custom study would be the best solution.
