Date/Time: Wed, 25 Nov 2026 23:10:09 +0000
Horizontal Grid
View Count: 372
| [2026-02-16 18:09:02] |
| User212556 - Posts: 7 |
Hi there, When using the horizontal grid on a plain chart the lines appear at round numbers 24700, 24800, 24900 etc, but when you add the chart dom to the chart the lines are displayed at an odd random number 24704.50, 24804.50, 24904.50 etc. Do you know why that is and how to keep it at the round numbers. Grid is spaced at 100 points. See images: https://www.sierrachart.com/image.php?Image=1771264951611.png https://www.sierrachart.com/image.php?Image=177126500531.png |
| [2026-02-16 22:18:29] |
This is on purpose. Refer to the following: Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-17 14:06:42] |
Hi John, I think you misunderstood what I was referring to in my query. I'm not worried about whether the lines are extended or not but the value at which they are drawn on the chart which changes depending on whether the DOM is attached or not. I edited two new images to explain more clearly: https://www.sierrachart.com/image.php?Image=1771337099571.png https://www.sierrachart.com/image.php?Image=1771337128914.png |
| [2026-02-17 16:10:01] |
This is due to what is stated in the post #2. If you want the lines to not shift when the DOM is turned on, then set the referenced setting to "No" and the lines will not be displayed in the DOM and will not be offset. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
