Date/Time: Wed, 25 Nov 2026 23:00:13 +0000
configure horizontal line at time
View Count: 363
| [2026-02-14 17:12:14] |
| cm85 - Posts: 3 |
is it possible to maintain the horizontal line at time from friday into the trading session on monday? i've played with the settings and cannot get a consistent result. note, in the graphic, the lines at time are stacked from the weekend. |
| Attachment Deleted. |
| [2026-02-16 15:31:35] |
If the start time of your line is outside the hours in which trading occurs on Sunday, then set the following Inputs for that study as noted below: - Use Allowed Range for Match in Minutes: Yes - Allowed Range for Match in Minutes: set this to the bar period you are using For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
