Date/Time: Tue, 13 Oct 2026 16:42:08 +0000
General questions about Rithmic data only and Sierrachart
View Count: 546
| [2026-02-14 04:37:31] |
| brunon109 - Posts: 2 |
Hi Sierra Chart Support, I have a couple of setup questions to make sure I understand how everything works before moving forward: If I am only paper trading and using Rithmic Trader Pro for charting, do I need to have a broker connected to Sierra Chart, or can I use Sierra Chart with Rithmic alone? If I purchase a Sierra Chart package (for example, Level 10 or above), will I receive live market data from Rithmic without having an active brokerage account connected, or would the data be delayed in that case? I want to ensure I fully understand the setup requirements so I can configure everything correctly. Thank you for your help! |
| [2026-02-16 15:15:43] |
| John - SC Support - Posts: 48189 |
You can use Sierra Chart with Rithmic for both trading and data. So you would not need a specific brokerage account in this case, as you are getting the data from Rithmic. Just be aware that Rithmic has a lack of historical data, so if you need historical data, then we recommend using our Denali Exchange Data Feed instead, where you would need a brokerage account in order to get the CME Group data at the Non-Professional rates. If I purchase a Sierra Chart package (for example, Level 10 or above), will I receive live market data from Rithmic without having an active brokerage account connected, or would the data be delayed in that case?
See our answer above For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
