Date/Time: Wed, 25 Nov 2026 23:00:19 +0000
s_UseTool::DrawingType: DRAWING_RECTANGLEHIGHLIGHT
View Count: 658
| [2026-02-13 20:54:19] |
| User688525 - Posts: 403 |
Hello Sierra Chart, I have a study that draws rectangles DRAWING_RECTANGLEHIGHLIGHT on a source chart as well as a destination chart. The drawings are drawn correctly, however, on the destination chart the Drawing Type (Manage Chart Drawings Window) is "Rectangle", not "Rectangle Highlight". As I am scanning user-drawn chart drawings using sc.GetUserDrawnChartDrawing() on the destination chart, the "Rectangle" isn't being detected as this isn't supported by "s_UseTool::DrawingType" (Using Drawing Tools From an Advanced Custom Study: s_UseTool::DrawingType). Are there any options to detect the "Rectangle" either through supporting DRAWING_RECTANGLEHIGHLIGHT and DRAWING_RECTANGLE_EXT_HIGHLIGHT on the destination chart or adding support for DRAWING_RECTANGLE in "s_UseTool::DrawingType"? Thank you |
| [2026-02-13 22:58:33] |
| Sierra_Chart Engineering - Posts: 25484 |
DRAWING_RECTANGLEHIGHLIGHT is a Rectangle drawing. They are both the same.
| [2026-02-14 01:50:20] |
Noted. Thank you.
