Date/Time: Wed, 25 Nov 2026 23:10:05 +0000
replay charts very choppy
View Count: 422
[2026-02-13 16:53:47]
User449884 - Posts: 238
replay charts are very choppy and clunky price action. been using replay for years but all of a sudden its not usable
[2026-02-13 18:52:35]
What are your settings for the Replay?
[2026-02-14 00:09:53]
standard replay
BY time
unit 00;00;00
skip emoty
[2026-02-16 15:06:12]
There have been no changes to the replay, so there is nothing that would cause a change in how it is working.
Are you replaying a single chart or multiple charts?
What is the replay speed you are using?
Be sure to try replaying a simple single chart and see how it works. Then add more complexity. The idea is to see where the issue is coming from - particularly in terms of either the studies on the chart or replaying multiple charts.
[2026-02-18 00:34:22]
ive tried everything, its a CB i use only for replay, ive never had to change settings but ever since i reinstalled SC its been acting wonky
ive included it, maybe you can see something i dont
Private File
[2026-02-18 14:51:38]
We do not see any issues with replaying the charts in your chartbook. The replay is working just fine and does not show any choppiness.
Since these are Trading DOMs, the only thing we can point you to is the following:
Replaying Charts: Replaying Trade DOM Windows
And also look at the section below it related to the Market Depth, as we wonder if what you might be seeing is simply due to not having Market Depth data for certain time periods.
[2026-02-18 15:15:08]
thank you
