Date/Time: Wed, 25 Nov 2026 23:00:13 +0000
arrow text left/right and above /below flipped?
View Count: 344
[2026-02-13 13:54:23]
User59879 - Posts: 85
I have just upgraded to version 2880 64-bit, and it seems that now on my arrows the text is placed in the wrong location; ie: if I configure "left", text appears to the right of the arrow, same for above/below.
It seems as if both horizontal and vertical alignment is now flipped.
[2026-02-13 23:19:40]
Sierra_Chart Engineering - Posts: 25484
We verified that the alignment is correct and as is intended.
You need to look at the Text as if it is a rectangle and right alignment means that the point where the Text rectangle is placed is according to the right side of its rectangle.
The same thing applies for above and below alignment.
