Date/Time: Fri, 09 Oct 2026 12:59:50 +0000
Switching to CQG/Rithmic
View Count: 705
| [2026-02-12 17:04:12] |
| Jimmyy - Posts: 341 |
I will have to unfortunately switch from Teton to either CQG or Rithmic because even upon multiple requests, SC is not providing market data for Nasdaq Cash index, the second biggest index in the world. With which service (CQG/Rithmic) will I be able to get Nasdaq cash index into my SC smoothly? For trading CME, I will continue to use Denali data. |
| [2026-02-12 19:06:07] |
| John - SC Support - Posts: 48161 |
Either CQG or Rithmic would be fine. We do not know which of them offers that particular index, so check which of them has it (most likely CQG has the data).
| [2026-03-04 16:03:57] |
So, I am getting NDX data from IBKR and its working pretty well. There is just one issue and that is that after every candle close, for the new candle, the open price is being registered as the last price of the previous candle which most of the times is not the case. And so, I have to re download the data at every new candle to fix it. Just letting yall know incase if its fixable. |
| [2026-03-04 16:42:08] |
Please get us a "Before" and "After" image of this situation. So before you redownload the data and then after you redownload the data. Follow these instructions to get us the images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) If there is a particular area that shows this more explicitly, then please point out where this is located in the images. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-04 17:06:31] |
Check the open price of the newest green candle where my cursor is (before and after) and check the last price of the red candle
Date Time Of Last Edit: 2026-03-04 17:06:47
| [2026-03-05 06:18:28] |
| Sierra_Chart Engineering - Posts: 25111 |
We are not able to solve this. This is just the behavior of the Interactive Brokers data feed.
| [2026-06-05 16:47:20] |
Can you guys please look into this one more time. im losing money during fast markets because i have to keep redownloading it at every candle
| [2026-06-05 22:19:21] |
What are these settings set to: Sierra Chart Server Settings >> General >> General >> Max Depth Levels : Sierra Chart Server Settings >> General >> General >> Use Real-Time Data Compression : {"No Compression", "Standard Compression", "High Compression"} Sierra Chart Server Settings >> General >> General >> Remote Buffer Delay Send Time in Milliseconds: Are you referring to CME data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-06-05 22:19:32
| [2026-06-09 12:42:17] |
Depth level : 100 Compression: Standard Compression Delay : 100 I am referring to the data coming from Interactive Brokers for the NDX-IND-NASDAQ ticker. |
| [2026-06-09 20:57:11] |
We cannot help with Interactive Brokers data issues.
| [2026-09-22 14:37:59] |
I understand your hesitation with IBKR data but I feel this can be fixable. The data is working very well. No issues, no lags at all. Its just that for some reason for every new candle the open price is being registered the same as the last price of the previous candle. I am sure there's something that can be fixed to prevent this because if i delete and redownload the data it becomes proper. This would save me a lot of trouble of then having to get the data from elsewhere like CQG (which as per you'll probably will have its own issues), etc. |
| [2026-09-22 15:42:24] |
This is the data that is coming from Interactive Brokers. So you would need to direct the questions on this to them. If they are sending different information in live from their historical data, then this is what they are doing, and again, you would need to ask them about this.
