Date/Time: Tue, 13 Oct 2026 16:42:02 +0000
Delayed data
View Count: 266
| [2026-02-12 09:00:43] |
| User990654 - Posts: 7 |
Hi, I receive delayed data (10mn) and I don't understand why. Could you check it out ? Thanks a lot, Regards, Ralph. |
| [2026-02-12 13:44:25] |
| Sierra_Chart Engineering - Posts: 25163 |
You do not have any exchanges active. Activate the exchanges that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
