Date/Time: Wed, 25 Nov 2026 23:00:11 +0000
[Programming Help] - 3 second chart lag
View Count: 433
[2026-02-11 17:26:11]
User700573 - Posts: 16
Hi, I am getting a 3-second chart lag. This just started today, yesterday it was fine - a 500 millisecond or less lag. I downloaded the current version and the 3 second lag is still there. What can I do? It is an NQ chart.
[2026-02-11 19:15:00]
What are you seeing that gives the impression that you have a 3 second lag?
If this is the "DD:" display in the Chart Header, then this is a difference between your computer's clock and the clock used by the exchange to timestamp the trades. A small number, like 3 seconds, usually indicates that your computer clock is off by that amount. Refer to the following for an option to setup NTP (Network Time Protocol) through Sierra Chart:
Network Time Protocol Client
