Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
DOM chart / shorcut
View Count: 380
| [2026-02-11 16:27:48] |
| User166249 - Posts: 28 |
Hi -how can i set the price line on the DOM chart? - how can i set the number of stock on the BOM chart? - my keyboard shortcut for hand tool is not working anymore (alt + H)? - how can i make the BUY or ASK light turn on when buyers or sellers hit the market? - if i upgrade my sierra from advanced 11 to advanced 1é do i hace to re install it again? thak you for your help |
| [2026-02-11 16:33:32] |
Use the "Current Price Line" study. Refer to the following: Current Price Line To get this on a Trading DOM, refer to the following: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM - how can i set the number of stock on the BOM chart?
We do not know what you are referring to or what exactly you are wanting. - my keyboard shortcut for hand tool is not working anymore (alt + H)?
Check the settings for the Keyboard Shortcuts and reassign it if it is no longer assigned as you want it. Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) - how can i make the BUY or ASK light turn on when buyers or sellers hit the market?
We need more information on exactly what you are wanting in this case. What do you want to see/change? - if i upgrade my sierra from advanced 11 to advanced 1é do i hace to re install it again?
You do not need to do anything with the software if you change your package. Refer to the instructions at the following link for how to change your package: Sierra Chart Purchase and License Information: Changing Package For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
