Date/Time: Wed, 25 Nov 2026 23:00:19 +0000
fichier csv
View Count: 389
[2026-02-11 16:26:31]
Jlo98 - Posts: 2
je souhaite exporter mes donnees de trading dans un journal en csv.
quelle est la manipulation ??
[2026-02-11 16:27:12]
From Google Translate:
I want to export my trading data to a CSV journal.
What's the procedure?
Refer to the following:
Trade Activity Log: Saving to a Text File
[2026-02-12 20:47:48]
Jlo98 - Posts: 2
Bonjour
Suite a votre message, je n'arrive toujours pas a transcire le fichier .txt en csv.
Apres avoir enregistré le fichier dans trade activty log , qd le l'envoie sur la passerelle hubtrading, il ne reconnais pas le fichier comme un fichier csv.
Merci de m'orienter .
Cordialement
[2026-02-12 20:54:37]
Hello
Following your message, I'm still unable to convert the .txt file to CSV.
After saving the file in Trade Activity Log, when I send it to the HubTrading gateway, it doesn't recognize the file as a CSV.
Please guide me.
Sincerely,
The file that is saved is "Tab Delimited". If you have an option to import a Tab Delimited file, then use that option. Otherwise, if you must be "Comma Separated Values" (CSV) the you would need to convert it. One way to convert to a CSV would be to import the information into Excel using the Tab Delimited option, then save as a CSV.
