Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
Write Bar and Study Data To File study - delays in writing to file
View Count: 644
[2026-02-11 12:01:39]
User604958 - Posts: 5
Hi Team,
Please help me understand potential delays in writing to file when using "Write Bar and Study Data To File" study on a 1-minute chart.
Issue description:
I have added "Write Bar and Study Data To File" study to a 1-minute chart of ZNH26 futures contract, on a trading evaluator account. My expectation was that Sierra Chart would write to a designated file every minute, on the minute, when a 1-minute bar is closed.
What I'm seeing instead is that the file is updated roughly every minute, but the exact time of update varies quite a bit. Sometimes it's a delay of 3 seconds, sometimes as much as 37 seconds. I confirmed it's not an issue with the file watcher - these are actual file modify timestamps.
File updated, modify date: 2026-02-11 12:40:03.009
File updated, modify date: 2026-02-11 12:41:28.309
File updated, modify date: 2026-02-11 12:42:27.931
File updated, modify date: 2026-02-11 12:43:03.241
File updated, modify date: 2026-02-11 12:44:05.103
File updated, modify date: 2026-02-11 12:45:00.606
File updated, modify date: 2026-02-11 12:47:06.487
File updated, modify date: 2026-02-11 12:48:37.148
File updated, modify date: 2026-02-11 12:49:08.631
File updated, modify date: 2026-02-11 12:50:16.025
Can you help me understand what factors may influence these delays please.
Thank you
[2026-02-11 12:52:25]
User150671 - Posts: 80
I can't be sure what time zone you are using, I am going to assume it is UTC+1 though
So the first trade post 11:49:59 is at 2026-02-11 11:50:15.173000+00:00 this matches your write time of 12:50:16.025
The first trade post 11:48:59 is at 2026-02-11 11:49:07.995000+00:00 so that also matches your write time of 2026-02-11 12:49:08.631.
If Sierra is updating the chart when it gets the next tick of trade post the bar close, that would be when the study writes out.
Date Time Of Last Edit: 2026-02-11 13:11:54
[2026-02-11 14:21:25]
I think you're spot on User150671 - this seems to be what's happening, ie. Sierra waits for the next tick post the bar close before writing to file. Thanks for pointing that out.
I wonder if there is a way to force the study to write to file on the bar close instead, without waiting for next tick.
Date Time Of Last Edit: 2026-02-11 14:22:34
[2026-02-11 16:09:59]
No, as Sierra Chart has no way to know that a bar is actually closed until the next bar starts.
[2026-02-11 19:15:13]
Thanks for confirming John
[2026-02-11 19:35:58]
If you need the data to be written live there are a couple of solutions:
- watching the SCID Files and writing the data out as it updates (tick data)
- setting the bar period lower (e.g. 1 second)
Either way you can then pull the data into something like pandas and then resample it into 1m bars or whatever time period you need.
