Date/Time: Wed, 18 Nov 2026 09:39:47 +0000
Native Option to Display Only the Current Forming Bar
View Count: 499
| [2026-02-11 09:07:25] |
| lctrading - Posts: 1 |
Dear Sierra Chart Engineering, I would like to request a native chart option to display only the currently forming bar, with all historical bars hidden visually. Currently, this can only be approximated using "Color Bar Based on Alert Condition", which is not fully native and can interfere with scaling or visual consistency. Proposed behavior: Add a chart setting such as "Display Current Bar Only". This would function purely as a visual filter. Historical bars remain loaded and calculated internally. Only the active bar is rendered. Use case: This would be useful for real-time execution training, footprint analysis, and studying live bar construction without historical visual anchoring. Thank you for considering this request. Kind regards, Tim |
| [2026-02-23 01:21:36] |
| Sierra_Chart Engineering - Posts: 25439 |
We have an idea how we could implement this without a lot of difficulty. We will work on that.
| [2026-03-19 06:21:06] |
This has been added to Chart Settings: Chart Settings >> Display >> Chart Display Items >> Display Last Bar Only The bar displays on the left side of the chart and as the best we can do right now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
