Date/Time: Wed, 25 Nov 2026 23:00:15 +0000
No such file or directory
View Count: 354
[2026-02-10 16:26:49]
cmack1011 - Posts: 201
When I try to compile a custom study, I get this error message even though the file name does exist. I believe this is a cache refresh issue? I will attach the message log as well. Of course, I don't want to have to delete the contents of the folder to refresh. Thx : -- Starting remote build of Custom Studies Source files: HOLD_GS2_Feature_Exporter_v12_19_VAP_FINISHDELTA_RECENCY2_TRIPLETAGG_v1.cpp. 64-bit -- 10:24:36
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
The remote build is complete.
The build failed.
x86_64-w64-mingw32-g++: error: HOLD_GS2_Feature_Exporter_v12_19_VAP_FINISHDELTA_RECENCY2_TR.cpp: No such file or directory
Failed to generate the dll file.
-- End of Build -- 10:24:37
imageScreenshot 2026-02-10 102337.png / V - Attached On 2026-02-10 16:26:06 UTC - Size: 560.67 KB - 202 views
[2026-02-10 18:43:13]
Your filename is too long. You need to shorten it for the remote build to be able to process it.
