Date/Time: Wed, 25 Nov 2026 23:01:19 +0000
how to increase rows on dom
View Count: 578
[2026-02-10 16:07:01]
ldepadey - Posts: 73
hi, is there a way to increase number for rows for dom? please find screenshot attached.. thanks.
[2026-02-10 18:41:49]
There is no screenshot attached.
We are not understanding what you are wanting to do.
You can expand/contract the Price Ladder as desired. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
[2026-02-11 07:37:40]
image should be uploaded now,basically just would like more rows in the dom so its possible to see more price from top to bottom
thanks
imagedom1.png / V - Attached On 2026-02-11 07:36:40 UTC - Size: 89.92 KB - 170 views
[2026-02-11 15:52:59]
It looks like you want to adjust the ladder by contracting the prices closer together. Again, refer to the following:
The only other option is to expand the size of the window itself, but it looks like it is already as tall as you can get it.
[2026-02-11 19:48:19]
the link you said is regarding charts, this is a dom and there is no interactive scale that can be adjusted by clicking and dragging.
Date Time Of Last Edit: 2026-02-11 19:48:33
[2026-02-11 19:52:18]
found the setting here, thanks
imageweweweff.png / V - Attached On 2026-02-11 19:52:03 UTC - Size: 41.89 KB - 153 views
[2026-02-11 20:50:19]
You can adjust the size of the Trading DOM in the same way as a Chart (Trading DOM is a specialized chart). Right-click and select "Interactive Scale Range" and then drag up/down to adjust the spacing.
