Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
Trade DOM (coloring problem)
View Count: 571
[2026-02-10 15:22:25]
blt - Posts: 233
to:
SIERRA CHART-Support
This should be easy one:
Ver. 2880
OS Win 11 pro
Chart-->Graphics Settings-Chart...(Use Global Graphics Settings...UNCHECKED)
option:
"Trade DOM Current Traded Ask Volume Bid Volume Difference Negative Volume Bar" can't be color adjusted and saved (stays gray all the time)
The same option but ..."Positive Volume Bar"...works fine
Thank you
[2026-02-10 18:29:30]
That option has not been completed yet. It will be implemented soon.
[2026-02-13 16:38:17]
kvcornie - Posts: 56
John,
I am not able to see the bar as an option to even put on the chart DOM (under Trade/Customize Chart DOM Columns).
Is the actual plot function not complete or do you mean the ability to change the color (because I am able to change color), just can't seem to plot the "Trade DOM Current Traded Ask Volume Bid Volume Difference Negative Volume Bar".
[2026-02-13 16:44:42]
blt - Posts: 233
@kvcornie
I was referring to columns on DOM not a chart DOM
[2026-02-13 18:49:19]
The option for "Trade DOM Current Traded Ask Volume Bid Volume Difference Negative Volume Bar" is now working in release 2882, which is a Pre-Release. To update, follow these instructions:
[2026-02-13 18:51:32]
kvcornie:
You first need to add the column you want. There are new columns for the following:
- Current Traded Ask Minus Bid Volume
- Current Traded Diagonal Ask Minus Bid Volume
Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
Then you need to specify that you want the Volume Bar displayed in that column. Refer to the following:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
Then you can set the colors as you want.
