Date/Time: Wed, 25 Nov 2026 23:00:08 +0000
New tws api
View Count: 2619
| [2026-02-10 00:22:10] |
| User472677 - Posts: 400 |
Hi Ib has a new tws api. Changes are mandatory and effective Feb 23. Is there a new sc version coming so that sc keeps on working with tws. |
| [2026-02-10 00:24:43] |
Important: TWS API 10.44 Changes Effective February 23, 2026 U1517001 | Lovii R Arora | - | 2026/02/09 IBCS 2026-02-09 08:08:55 EST Dear Client, What Is Happening? Beginning with the release of Trader Workstation and IBKR Gateway 10.44, the “LAST_SIZE” and “DELAYED_LAST_SIZE” tick type delivered to the EWrapper.tickSize size argument will act as a Decimal-type value instead of an Integer-type value. Why Is This Happening? This change will allow Interactive Brokers to pass fractional trade sizes when requesting market data with EClient.reqMktData. Who Is Affected? Anyone who updates their TWS API version to 10.44 and above. When Does This Take Effect? The LAST_SIZE and DELAYED_LAST_SIZE values will deliver fractional sizes beginning February 23, 2026. How Should You Prepare? In code that implements EWrapper.tickSize() alongside EClient.reqMktData(), ensure that the final variable, size, can accept a Decimal value. In addition, ensure that any internal systems that utilize LAST_SIZE (ticktype 5) or DELAYED_LAST_SIZE (ticktype 76) can accept a Decimal variable. |
| [2026-02-10 01:22:19] |
| Sierra_Chart Engineering - Posts: 25484 |
The necessary changes have been completed in Sierra Chart. Update to the current version: Software Download: Fast Update Even if you do not update, there should not be any problem based upon how Sierra Chart is integrated with TWS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
