Date/Time: Wed, 25 Nov 2026 23:00:07 +0000
Change names of tabs
View Count: 472
| [2026-02-09 20:35:53] |
| User459067 - Posts: 5 |
Hellow ! I dont know how to rename tabs ? |
| [2026-02-09 20:38:04] |
We are not sure if those are the Chartbook or the Chart tabs. If they are the Chartbook tabs, then you need to save the chartbook to a different name. The tab is always going to show the saved name of the chartbook. Refer to the following: Chartbooks (Workspaces): To Save a Chartbook If those are Chart tabs, then you can set the "Title Bar Name", which is what is displayed in the Title Bar, and then use that name as the tab name. Refer to the following and the setting below it: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
