Date/Time: Wed, 25 Nov 2026 23:00:11 +0000
Moving from a 21:9 Monitor to 16:9
View Count: 341
| [2026-02-09 16:35:14] |
| User453636 - Posts: 28 |
Dear Suppor Team! I have switched from a 21:9 to a 16:9 monitor. Saved my CB, but my DOM panel were way out on the far right, and wont show up on the smaller monitor. Tryed to deattach - reattach it, minimaise it, but didnt helped much. Can you be so kind and help me with this? |
| [2026-02-09 18:35:25] |
Select "Window >> Reset Windows" and see if this brings it into view. If not, then do an Internet search for "move windows off screen", and you will find options for how to solve this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
