Date/Time: Wed, 25 Nov 2026 23:00:11 +0000
BUG - current trades column not sizing correctly but works as soon as replay starts
View Count: 375
| [2026-02-09 07:48:24] |
| User350373 - Posts: 11 |
The sizing of the current trades columns is all of the sudden misaligned and looking odd. First screen shot shows the live dom on MES right now. The second screen shot is from 5 seconds later after starting a market replay. not sure why it looks like this without the replay and then fixes itself during the replay before reverting back after replay is stopped. Currently have tick size at 1 for MES market depth combine increment is set to 1, and volume by price increment set to 4 ticks. |
| [2026-02-09 18:06:07] |
Which image is which? Please reference them by the actual filenames. And we are not seeing any issue with the Market Depth for MES at this time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-09 18:07:46] |
| Sierra_Chart Engineering - Posts: 25484 |
This is not going to work right: Currently have tick size at 1 for MES market depth combine increment is set to 1, and volume by price increment set to 4 ticks. Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-09 22:42:28] |
The screen shot ending in 411 is the image with the misaligned column bars, and the image ending in 433 is the replay where it shows correctly. This is not going to work right:
It works just fine in replay? And besides the glitched volume bars outside replay it is still functional as far as I can tell. |
| [2026-02-09 23:11:28] |
It may work fine in a replay, but technically, when combining levels, it has to be done as explained here: Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
