Date/Time: Wed, 25 Nov 2026 23:00:12 +0000
ver 2875 offline documentation
View Count: 436
| [2026-02-09 04:31:08] |
| User517409 - Posts: 1 |
I use 2 AI's to answer most of my support questions. The most current offline SC documentation I have found on your Documentation page (SierraChartDocumentation.zip) is seriously outdated (see note) in many areas and bloated w/dead links. When converted to a .md file it is over 13 Gb. If you choose to believe the AI, there is > 3 Gb of dead links in there. Does a cleaner, more up to date offline docs scrape (in any format) exist anywhere? Thank you, Palmer Trans_User_palm4269 Note: when requesting help to setup "Number Bars indicator" thru the AI after feeding it this doc, the responses were based on 2022 menu choices, ie: Chart Settings. |
| [2026-02-10 00:04:35] |
The zip file's Chart Settings documentation file was Last modified Sunday, 04th January, 2026. Which is up to date. And there is only one zip file which is replaced on a daily basis. Can you give us examples of the "dead links"? It makes no sense for dead links to use up 3gb of space. Also note that the unzipped file is 59 MB. Where are you getting your file sizes from? Sierra Chart Support Date Time Of Last Edit: 2026-02-10 00:09:19
