Date/Time: Wed, 25 Nov 2026 23:00:12 +0000
Entry price multiplied 1000 times on a micro contract
View Count: 396
| [2026-02-08 21:54:11] |
| User554292 - Posts: 2 |
Hello, I have the following problem. I'm set to trade a large contract on a small contract, but the trade log shows the price multiplied by 1000. What's wrong?
| Attachment Deleted. |
| [2026-02-08 22:18:54] |
| Sierra_Chart Engineering - Posts: 25484 |
The solution to this is explained here: Sierra Chart Teton Futures Order Routing: Using Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-09 15:43:52] |
Sorry, still not working.
| [2026-02-09 16:10:25] |
Changes to these Chart Settings will not affect existing fills: Price Display Format: .00001 Tick Size: .0001 Trade and Current Quote Symbol Price Multiplier: 1 And make sure the Tick Size is as shown above. You have it smaller. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-09 16:10:40
