Date/Time: Wed, 25 Nov 2026 23:00:10 +0000
TA: Unset
View Count: 491
[2026-02-08 18:13:31]
User361996 - Posts: 3
Hi, I have already set up on my primary computer the connection to AMP TETON without any problem, but i have replicated exactly the same on my backup computer and on this backup computer the charts shows TA: Unset (on primary computer my AMP account is shown and everything works fine). If i go to the account balance window, my account is perfectly displayed as well as my balance, but the charts are not connected to the account showing TA: Unset which i believe will result in not being able to trade from it or flatten positions.
As said before, on my primary computer everything is working fine but on the backup one i am facing this problem (even when primary computer is logged off).
Thanks for your help as i am new to SierraChart.
Best regards
Private File
[2026-02-09 17:19:25]
In the field where you select the "Trade Account" on the Trade Window, if you open this up, do you see the account you want and can you select it?
Refer to the following:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
[2026-02-09 18:46:13]
No, it is blank and when the field is open also blank and nothing to select from. Also real time data (Denali) is not working despite having it connected and having purchased double data in order to be able to have real time in both computers. I guess the real time date issue is linked to the account connectivity issue.
imageSC account selection.png / V - Attached On 2026-02-09 18:37:48 UTC - Size: 209.9 KB - 186 views
[2026-02-09 19:09:37]
On the computer where you are having the issue, what is the following set to:
- Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service
Also, please get us your "Trade >> Trade Service Log" by following these instructions:
Support Board Posting Information: Providing Lines From Trade Service Log
[2026-02-09 20:01:55]
The issue was related to the path you mentioned: - Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service
Once that was reviewed and corrected, the problem was fully resolved. Both computers are now working simultaneously without any issues, and i am also receiving real time data on both.
I really appreciate your help and the great support provided.
